Time Before: 0.00168 seconds
Time After: 0.00222 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00229 seconds
Time After: 0.00278 seconds
Time Before: 0.00297 seconds
Time After: 0.00311 seconds
Time Before: 0.00406 seconds
Time After: 0.00712 seconds
Time Taken: 0.00306 seconds
Time Before: 0.00319 seconds
Time After: 0.01183 seconds
Time Taken: 0.00864 seconds
Time Before: 0.01406 seconds
Time After: 0.01450 seconds
Time Before: 0.01609 seconds
Time After: 0.01741 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01339 seconds
Time After: 0.01761 seconds
Time Taken: 0.00422 seconds
Time Before: 0.02281 seconds
Time After: 0.02298 seconds
Time Before: 0.02554 seconds
Time After: 0.02682 seconds
End call of global.php: 0.028450012207031
Time Before: 0.02977 seconds
Time After: 0.02993 seconds
Time Before: 0.03187 seconds
Time After: 0.03336 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109156', badlocation = 1
Time Before: 0.04652 seconds
Time After: 0.04686 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.045609951019287 seconds with 9 queries, spending 0.0088839530944824 doing MySQL queries and 0.036725997924805 doing PHP things.
