Time Before: 0.00223 seconds
Time After: 0.00307 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00315 seconds
Time After: 0.00364 seconds
Time Before: 0.00387 seconds
Time After: 0.00400 seconds
Time Before: 0.00478 seconds
Time After: 0.00729 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00405 seconds
Time After: 0.01064 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01237 seconds
Time After: 0.01279 seconds
Time Before: 0.01526 seconds
Time After: 0.01650 seconds
Time Before: 0.01178 seconds
Time After: 0.01672 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02341 seconds
Time After: 0.02355 seconds
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"10.12,\";s:9:\"lastcheck\";i:1789031326;}', 1)
Time Before: 0.02999 seconds
Time After: 0.03071 seconds
Time Taken: 0.00072 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.03354 seconds
Time After: 0.03479 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
End call of global.php: 0.038151025772095
Time Before: 0.03958 seconds
Time After: 0.03974 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.04243 seconds
Time After: 0.04387 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
SET lastactivity = 1789031326, location = '/forums/private.php?do=newpm&explain=1&u=109160', badlocation = 1
Time Before: 0.06160 seconds
Time After: 0.06262 seconds
Time Taken: 0.00102 seconds
Memory Before: 4,920.063 KB
Memory After: 4,920.273 KB
Page generated in 0.060168027877808 seconds with 10 queries, spending 0.0095179080963135 doing MySQL queries and 0.050650119781494 doing PHP things.
