Time Before: 0.00884 seconds
Time After: 0.01262 seconds
Time Taken: 0.00379 seconds
Time Before: 0.01270 seconds
Time After: 0.01316 seconds
Time Before: 0.01345 seconds
Time After: 0.01360 seconds
Time Before: 0.01445 seconds
Time After: 0.01824 seconds
Time Before: 0.01368 seconds
Time After: 0.02264 seconds
Time Taken: 0.00896 seconds
Time Before: 0.02702 seconds
Time After: 0.02751 seconds
Time Before: 0.02878 seconds
Time After: 0.03007 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02619 seconds
Time After: 0.03025 seconds
Time Taken: 0.00406 seconds
Memory After: 2,261.820 KB
Time Before: 0.04264 seconds
Time After: 0.04279 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05140 seconds
Time After: 0.05264 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.05859 seconds
Time After: 0.05878 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06176 seconds
Time After: 0.06322 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789034187, location = '/forums/private.php?do=newpm&explain=1&u=109193' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07939 seconds
Time After: 0.07981 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
