Time Before: 0.00178 seconds
Time After: 0.00238 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00246 seconds
Time After: 0.00311 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00339 seconds
Time After: 0.00352 seconds
Time Before: 0.00423 seconds
Time After: 0.00692 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00357 seconds
Time After: 0.01034 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01205 seconds
Time After: 0.01224 seconds
Time Before: 0.01499 seconds
Time After: 0.01623 seconds
Time Before: 0.01151 seconds
Time After: 0.01639 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02141 seconds
Time After: 0.02156 seconds
Time Before: 0.02389 seconds
Time After: 0.02516 seconds
Time Before: 0.02898 seconds
Time After: 0.02915 seconds
Time Before: 0.03192 seconds
Time After: 0.03335 seconds
UPDATE session SET lastactivity = 1784768963, location = '/forums/private.php?do=newpm&explain=1&u=109226', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04645 seconds
Time After: 0.04674 seconds
