Time Before: 0.00136 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00234 seconds
Time Before: 0.00307 seconds
Time After: 0.00352 seconds
Time Before: 0.00438 seconds
Time After: 0.00714 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00360 seconds
Time After: 0.01221 seconds
Time Taken: 0.00861 seconds
Time Before: 0.01444 seconds
Time After: 0.01495 seconds
Time Before: 0.01756 seconds
Time After: 0.01876 seconds
Time Before: 0.01371 seconds
Time After: 0.01900 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02495 seconds
Time After: 0.02512 seconds
Time Before: 0.02745 seconds
Time After: 0.02868 seconds
Time Before: 0.03264 seconds
Time After: 0.03283 seconds
Time Before: 0.03515 seconds
Time After: 0.03657 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109247', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05150 seconds
Time After: 0.05232 seconds
Time Taken: 0.00082 seconds
