Time Before: 0.02724 seconds
Time After: 0.03683 seconds
Time Taken: 0.00959 seconds
Time Before: 0.03694 seconds
Time After: 0.03735 seconds
Time Before: 0.03760 seconds
Time After: 0.03775 seconds
Time Before: 0.03864 seconds
Time After: 0.04114 seconds
Time Taken: 0.00250 seconds
Time Before: 0.03782 seconds
Time After: 0.04516 seconds
Time Taken: 0.00734 seconds
Time Before: 0.05764 seconds
Time After: 0.05807 seconds
Time Before: 0.06151 seconds
Time After: 0.06279 seconds
Time Before: 0.05684 seconds
Time After: 0.06301 seconds
Time Taken: 0.00617 seconds
Time Before: 0.11029 seconds
Time After: 0.11048 seconds
Time Before: 0.13154 seconds
Time After: 0.13282 seconds
End call of global.php: 0.13533687591553
Time Before: 0.14130 seconds
Time After: 0.14149 seconds
Time Before: 0.14401 seconds
Time After: 0.14548 seconds
SET lastactivity = 1783210233, location = '/forums/private.php?do=newpm&explain=1&u=109257'
Time Before: 0.16474 seconds
Time After: 0.16504 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.16354584693909 seconds with 9 queries, spending 0.0082073211669922 doing MySQL queries and 0.15533852577209 doing PHP things.
