Time Before: 0.00512 seconds
Time After: 0.00732 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00748 seconds
Time After: 0.00797 seconds
Time Before: 0.00819 seconds
Time After: 0.00833 seconds
Time Before: 0.00919 seconds
Time After: 0.01263 seconds
Time Taken: 0.00344 seconds
Time Before: 0.00845 seconds
Time After: 0.01727 seconds
Time Taken: 0.00882 seconds
Time Before: 0.02062 seconds
Time After: 0.02107 seconds
Time Before: 0.02373 seconds
Time After: 0.02591 seconds
Time Taken: 0.00218 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01987 seconds
Time After: 0.02621 seconds
Time Taken: 0.00633 seconds
Memory After: 2,261.703 KB
Time Before: 0.03344 seconds
Time After: 0.03357 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03920 seconds
Time After: 0.04046 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.042603969573975
Time Before: 0.04568 seconds
Time After: 0.04581 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04814 seconds
Time After: 0.04958 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=109260'
Time Before: 0.06272 seconds
Time After: 0.06322 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.061820983886719 seconds with 9 queries, spending 0.010161876678467 doing MySQL queries and 0.051659107208252 doing PHP things.
