Time Before: 0.01851 seconds
Time After: 0.02315 seconds
Time Taken: 0.00464 seconds
Time Before: 0.02327 seconds
Time After: 0.02384 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02411 seconds
Time After: 0.02428 seconds
Time Before: 0.02518 seconds
Time After: 0.02762 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02436 seconds
Time After: 0.03204 seconds
Time Taken: 0.00768 seconds
Time Before: 0.04187 seconds
Time After: 0.04232 seconds
Time Before: 0.04480 seconds
Time After: 0.04602 seconds
Time Before: 0.04106 seconds
Time After: 0.04621 seconds
Time Taken: 0.00514 seconds
Time Before: 0.08815 seconds
Time After: 0.08835 seconds
Time Before: 0.10105 seconds
Time After: 0.10236 seconds
Time Taken: 0.00131 seconds
Time Before: 0.11225 seconds
Time After: 0.11242 seconds
Time Before: 0.11497 seconds
Time After: 0.11653 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109266' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.14150 seconds
Time After: 0.14182 seconds
