Time Before: 0.00136 seconds
Time After: 0.00180 seconds
Time Before: 0.00186 seconds
Time After: 0.00229 seconds
Time Before: 0.00250 seconds
Time After: 0.00263 seconds
Time Before: 0.00338 seconds
Time After: 0.00598 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00269 seconds
Time After: 0.00938 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01122 seconds
Time After: 0.01165 seconds
Time Before: 0.01412 seconds
Time After: 0.01533 seconds
Time Before: 0.01054 seconds
Time After: 0.01550 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02050 seconds
Time After: 0.02061 seconds
Time Before: 0.02242 seconds
Time After: 0.02363 seconds
Time Before: 0.02685 seconds
Time After: 0.02701 seconds
Time Before: 0.02931 seconds
Time After: 0.03081 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109287' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04488 seconds
Time After: 0.04514 seconds
