Time Before: 0.01334 seconds
Time After: 0.01748 seconds
Time Taken: 0.00414 seconds
Time Before: 0.01759 seconds
Time After: 0.01800 seconds
Time Before: 0.01824 seconds
Time After: 0.01837 seconds
Time Before: 0.01914 seconds
Time After: 0.02137 seconds
Time Taken: 0.00223 seconds
Time Before: 0.01843 seconds
Time After: 0.02521 seconds
Time Taken: 0.00678 seconds
Time Before: 0.03065 seconds
Time After: 0.03106 seconds
Time Before: 0.03390 seconds
Time After: 0.03510 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02995 seconds
Time After: 0.03535 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.703 KB
Time Before: 0.05356 seconds
Time After: 0.05370 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06667 seconds
Time After: 0.06795 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.070206165313721
Time Before: 0.07508 seconds
Time After: 0.07527 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07844 seconds
Time After: 0.07991 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=109351'
Time Before: 0.09764 seconds
Time After: 0.09803 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.096537113189697 seconds with 9 queries, spending 0.0078377723693848 doing MySQL queries and 0.088699340820312 doing PHP things.
