Time Before: 0.01816 seconds
Time After: 0.02288 seconds
Time Taken: 0.00472 seconds
Time Before: 0.02299 seconds
Time After: 0.02354 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02383 seconds
Time After: 0.02400 seconds
Time Before: 0.02486 seconds
Time After: 0.02719 seconds
Time Taken: 0.00233 seconds
Time Before: 0.02408 seconds
Time After: 0.03102 seconds
Time Taken: 0.00695 seconds
Time Before: 0.03648 seconds
Time After: 0.03691 seconds
Time Before: 0.03951 seconds
Time After: 0.04070 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03550 seconds
Time After: 0.04090 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.820 KB
Time Before: 0.07340 seconds
Time After: 0.07392 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09172 seconds
Time After: 0.09301 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10430 seconds
Time After: 0.10444 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10711 seconds
Time After: 0.10890 seconds
Time Taken: 0.00179 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788922305, location = '/forums/private.php?do=newpm&explain=1&u=109366', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12577 seconds
Time After: 0.12620 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
