Time Before: 0.00186 seconds
Time After: 0.00240 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00247 seconds
Time After: 0.00293 seconds
Time Before: 0.00318 seconds
Time After: 0.00334 seconds
Time Before: 0.00414 seconds
Time After: 0.00667 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00339 seconds
Time After: 0.01150 seconds
Time Taken: 0.00811 seconds
Time Before: 0.01325 seconds
Time After: 0.01372 seconds
Time Before: 0.01614 seconds
Time After: 0.01737 seconds
Time Before: 0.01268 seconds
Time After: 0.01754 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02379 seconds
Time After: 0.02391 seconds
Time Before: 0.02625 seconds
Time After: 0.02764 seconds
Time Taken: 0.00138 seconds
Time Before: 0.03125 seconds
Time After: 0.03145 seconds
Time Before: 0.03454 seconds
Time After: 0.03631 seconds
Time Taken: 0.00177 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109391', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05063 seconds
Time After: 0.05093 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
