Time Before: 0.00738 seconds
Time After: 0.01012 seconds
Time Taken: 0.00274 seconds
Time Before: 0.01019 seconds
Time After: 0.01060 seconds
Time Before: 0.01081 seconds
Time After: 0.01091 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01172 seconds
Time After: 0.01418 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01096 seconds
Time After: 0.01772 seconds
Time Taken: 0.00676 seconds
Time Before: 0.02085 seconds
Time After: 0.02125 seconds
Time Before: 0.02460 seconds
Time After: 0.02679 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02028 seconds
Time After: 0.02699 seconds
Time Taken: 0.00671 seconds
Time Before: 0.04402 seconds
Time After: 0.04415 seconds
Time Before: 0.05240 seconds
Time After: 0.05365 seconds
End call of global.php: 0.056535005569458
Time Before: 0.06034 seconds
Time After: 0.06054 seconds
Time Before: 0.06345 seconds
Time After: 0.06492 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109412'
Time Before: 0.08453 seconds
Time After: 0.08485 seconds
Page generated in 0.083118200302124 seconds with 9 queries, spending 0.0089316368103027 doing MySQL queries and 0.074186563491821 doing PHP things.
