Time Before: 0.00215 seconds
Time After: 0.00261 seconds
Time Before: 0.00268 seconds
Time After: 0.00314 seconds
Time Before: 0.00341 seconds
Time After: 0.00357 seconds
Time Before: 0.00438 seconds
Time After: 0.00660 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00361 seconds
Time After: 0.01029 seconds
Time Taken: 0.00667 seconds
Time Before: 0.01224 seconds
Time After: 0.01266 seconds
Time Before: 0.01597 seconds
Time After: 0.01721 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01158 seconds
Time After: 0.01738 seconds
Time Taken: 0.00579 seconds
Memory After: 2,261.703 KB
Time Before: 0.02666 seconds
Time After: 0.02682 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02878 seconds
Time After: 0.03004 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.031728029251099
Time Before: 0.03318 seconds
Time After: 0.03332 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03542 seconds
Time After: 0.03694 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=109422', badlocation = 1
Time Before: 0.04915 seconds
Time After: 0.04949 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.048230886459351 seconds with 9 queries, spending 0.0079209804534912 doing MySQL queries and 0.040309906005859 doing PHP things.
