Time Before: 0.00146 seconds
Time After: 0.00199 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00206 seconds
Time After: 0.00249 seconds
Time Before: 0.00273 seconds
Time After: 0.00286 seconds
Time Before: 0.00358 seconds
Time After: 0.00593 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00291 seconds
Time After: 0.00957 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01144 seconds
Time After: 0.01178 seconds
Time Before: 0.01425 seconds
Time After: 0.01546 seconds
Time Before: 0.01079 seconds
Time After: 0.01565 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02083 seconds
Time After: 0.02097 seconds
Time Before: 0.02301 seconds
Time After: 0.02424 seconds
Time Before: 0.02711 seconds
Time After: 0.02727 seconds
Time Before: 0.03012 seconds
Time After: 0.03158 seconds
UPDATE session SET lastactivity = 1783081410, location = '/forums/private.php?do=newpm&explain=1&u=109434', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04394 seconds
Time After: 0.04422 seconds
