Time Before: 0.00139 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00252 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00277 seconds
Time After: 0.00290 seconds
Time Before: 0.00357 seconds
Time After: 0.00638 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00295 seconds
Time After: 0.00974 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01213 seconds
Time After: 0.01257 seconds
Time Before: 0.01391 seconds
Time After: 0.01532 seconds
Time Before: 0.01145 seconds
Time After: 0.01549 seconds
Time Taken: 0.00404 seconds
Time Before: 0.02256 seconds
Time After: 0.02316 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02582 seconds
Time After: 0.02710 seconds
End call of global.php: 0.028795003890991
Time Before: 0.03016 seconds
Time After: 0.03039 seconds
Time Before: 0.03247 seconds
Time After: 0.03395 seconds
SET lastactivity = 1789077651, location = '/forums/private.php?do=newpm&explain=1&u=109504'
Time Before: 0.04649 seconds
Time After: 0.04676 seconds
Page generated in 0.045610904693604 seconds with 9 queries, spending 0.0092704296112061 doing MySQL queries and 0.036340475082397 doing PHP things.
