Time Before: 0.00996 seconds
Time After: 0.01383 seconds
Time Taken: 0.00386 seconds
Time Before: 0.01392 seconds
Time After: 0.01433 seconds
Time Before: 0.01456 seconds
Time After: 0.01468 seconds
Time Before: 0.01544 seconds
Time After: 0.01776 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01473 seconds
Time After: 0.02201 seconds
Time Taken: 0.00727 seconds
Time Before: 0.02916 seconds
Time After: 0.02935 seconds
Time Before: 0.03065 seconds
Time After: 0.03185 seconds
Time Before: 0.02840 seconds
Time After: 0.03204 seconds
Time Taken: 0.00364 seconds
Time Before: 0.05236 seconds
Time After: 0.05251 seconds
Time Before: 0.06552 seconds
Time After: 0.06748 seconds
Time Taken: 0.00196 seconds
Time Before: 0.07339 seconds
Time After: 0.07356 seconds
Time Before: 0.07579 seconds
Time After: 0.07721 seconds
UPDATE session SET lastactivity = 1784797642, location = '/forums/private.php?do=newpm&explain=1&u=109543', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.09431 seconds
Time After: 0.09464 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
