Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00252 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00296 seconds
Time After: 0.00311 seconds
Time Before: 0.00394 seconds
Time After: 0.00636 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00320 seconds
Time After: 0.01103 seconds
Time Taken: 0.00783 seconds
Time Before: 0.01289 seconds
Time After: 0.01333 seconds
Time Before: 0.01572 seconds
Time After: 0.01698 seconds
Time Before: 0.01231 seconds
Time After: 0.01714 seconds
Time Taken: 0.00484 seconds
Time Before: 0.02207 seconds
Time After: 0.02225 seconds
Time Before: 0.02409 seconds
Time After: 0.02534 seconds
Time Before: 0.02810 seconds
Time After: 0.02828 seconds
Time Before: 0.03022 seconds
Time After: 0.03167 seconds
UPDATE session SET lastactivity = 1785404323, location = '/forums/private.php?do=newpm&explain=1&u=109549' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04394 seconds
Time After: 0.04427 seconds
