Time Before: 0.00156 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00255 seconds
Time Before: 0.00274 seconds
Time After: 0.00285 seconds
Time Before: 0.00354 seconds
Time After: 0.00587 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00290 seconds
Time After: 0.00926 seconds
Time Taken: 0.00636 seconds
Time Before: 0.01110 seconds
Time After: 0.01136 seconds
Time Before: 0.01414 seconds
Time After: 0.01635 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01046 seconds
Time After: 0.01657 seconds
Time Taken: 0.00611 seconds
Time Before: 0.02181 seconds
Time After: 0.02194 seconds
Time Before: 0.02378 seconds
Time After: 0.02514 seconds
Time Taken: 0.00136 seconds
Time Before: 0.02818 seconds
Time After: 0.02831 seconds
Time Before: 0.03039 seconds
Time After: 0.03181 seconds
UPDATE session SET lastactivity = 1789055549, location = '/forums/private.php?do=newpm&explain=1&u=109558' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04439 seconds
Time After: 0.04479 seconds
