Time Before: 0.00147 seconds
Time After: 0.00230 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00240 seconds
Time After: 0.00298 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00329 seconds
Time After: 0.00341 seconds
Time Before: 0.00430 seconds
Time After: 0.00727 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00349 seconds
Time After: 0.01254 seconds
Time Taken: 0.00904 seconds
Time Before: 0.01530 seconds
Time After: 0.01575 seconds
Time Before: 0.01825 seconds
Time After: 0.01949 seconds
Time Before: 0.01450 seconds
Time After: 0.01975 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02732 seconds
Time After: 0.02748 seconds
Time Before: 0.02970 seconds
Time After: 0.03099 seconds
End call of global.php: 0.033879041671753
Time Before: 0.03571 seconds
Time After: 0.03588 seconds
Time Before: 0.03827 seconds
Time After: 0.03974 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=10957', badlocation = 1
Time Before: 0.05385 seconds
Time After: 0.05412 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.052860975265503 seconds with 9 queries, spending 0.0087156295776367 doing MySQL queries and 0.044145345687866 doing PHP things.
