Time Before: 0.02579 seconds
Time After: 0.03316 seconds
Time Taken: 0.00737 seconds
Time Before: 0.03324 seconds
Time After: 0.03364 seconds
Time Before: 0.03394 seconds
Time After: 0.03407 seconds
Time Before: 0.03488 seconds
Time After: 0.03728 seconds
Time Taken: 0.00239 seconds
Time Before: 0.03415 seconds
Time After: 0.04189 seconds
Time Taken: 0.00774 seconds
Time Before: 0.05132 seconds
Time After: 0.05172 seconds
Time Before: 0.05411 seconds
Time After: 0.05531 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05062 seconds
Time After: 0.05559 seconds
Time Taken: 0.00497 seconds
Memory After: 2,261.820 KB
Time Before: 0.11582 seconds
Time After: 0.11604 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.13474 seconds
Time After: 0.13684 seconds
Time Taken: 0.00209 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.14951 seconds
Time After: 0.14967 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.15249 seconds
Time After: 0.15396 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789052506, location = '/forums/private.php?do=newpm&explain=1&u=109637', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.17342 seconds
Time After: 0.17382 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
