Time Before: 0.00313 seconds
Time After: 0.00475 seconds
Time Taken: 0.00162 seconds
Time Before: 0.00486 seconds
Time After: 0.00530 seconds
Time Before: 0.00559 seconds
Time After: 0.00575 seconds
Time Before: 0.00672 seconds
Time After: 0.00925 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00582 seconds
Time After: 0.01554 seconds
Time Taken: 0.00972 seconds
Time Before: 0.01809 seconds
Time After: 0.01848 seconds
Time Before: 0.02112 seconds
Time After: 0.02238 seconds
Time Before: 0.01738 seconds
Time After: 0.02263 seconds
Time Taken: 0.00524 seconds
Time Before: 0.03048 seconds
Time After: 0.03071 seconds
Time Before: 0.03469 seconds
Time After: 0.03677 seconds
Time Taken: 0.00208 seconds
Time Before: 0.04177 seconds
Time After: 0.04203 seconds
Time Before: 0.04580 seconds
Time After: 0.04730 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109650', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.06362 seconds
Time After: 0.06387 seconds
