Time Before: 0.00198 seconds
Time After: 0.00319 seconds
Time Before: 0.00326 seconds
Time After: 0.00366 seconds
Time Before: 0.00387 seconds
Time After: 0.00406 seconds
Time Before: 0.00479 seconds
Time After: 0.00776 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00411 seconds
Time After: 0.01124 seconds
Time Taken: 0.00714 seconds
Time Before: 0.01343 seconds
Time After: 0.01395 seconds
Time Before: 0.01718 seconds
Time After: 0.01839 seconds
Time Before: 0.01268 seconds
Time After: 0.01857 seconds
Time Taken: 0.00589 seconds
Time Before: 0.02487 seconds
Time After: 0.02505 seconds
Time Before: 0.02752 seconds
Time After: 0.02934 seconds
Time Taken: 0.00182 seconds
End call of global.php: 0.032505035400391
Time Before: 0.03414 seconds
Time After: 0.03428 seconds
Time Before: 0.03687 seconds
Time After: 0.03886 seconds
Time Taken: 0.00199 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109676', badlocation = 1
Time Before: 0.05400 seconds
Time After: 0.05432 seconds
Page generated in 0.052560091018677 seconds with 9 queries, spending 0.0097260475158691 doing MySQL queries and 0.042834043502808 doing PHP things.
