Time Before: 0.00865 seconds
Time After: 0.01346 seconds
Time Taken: 0.00481 seconds
Time Before: 0.01357 seconds
Time After: 0.01398 seconds
Time Before: 0.01420 seconds
Time After: 0.01438 seconds
Time Before: 0.01516 seconds
Time After: 0.01886 seconds
Time Taken: 0.00370 seconds
Time Before: 0.01443 seconds
Time After: 0.02284 seconds
Time Taken: 0.00841 seconds
Time Before: 0.03077 seconds
Time After: 0.03118 seconds
Time Before: 0.03410 seconds
Time After: 0.03553 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02994 seconds
Time After: 0.03572 seconds
Time Taken: 0.00578 seconds
Memory After: 2,261.703 KB
Time Before: 0.05440 seconds
Time After: 0.05457 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06830 seconds
Time After: 0.06956 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.07778 seconds
Time After: 0.07793 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08028 seconds
Time After: 0.08170 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109677' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09831 seconds
Time After: 0.09857 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
