Time Before: 0.00309 seconds
Time After: 0.00466 seconds
Time Taken: 0.00157 seconds
Time Before: 0.00477 seconds
Time After: 0.00549 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00609 seconds
Time After: 0.00635 seconds
Time Before: 0.00734 seconds
Time After: 0.00971 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00644 seconds
Time After: 0.01519 seconds
Time Taken: 0.00875 seconds
Time Before: 0.01848 seconds
Time After: 0.01889 seconds
Time Before: 0.02211 seconds
Time After: 0.02337 seconds
Time Before: 0.01772 seconds
Time After: 0.02366 seconds
Time Taken: 0.00594 seconds
Time Before: 0.03207 seconds
Time After: 0.03238 seconds
Time Before: 0.03580 seconds
Time After: 0.03708 seconds
End call of global.php: 0.038866996765137
Time Before: 0.04127 seconds
Time After: 0.04141 seconds
Time Before: 0.04345 seconds
Time After: 0.04486 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109722', badlocation = 1
Time Before: 0.05784 seconds
Time After: 0.05810 seconds
Page generated in 0.056923151016235 seconds with 9 queries, spending 0.0084402561187744 doing MySQL queries and 0.048482894897461 doing PHP things.
