Time Before: 0.00737 seconds
Time After: 0.00959 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00967 seconds
Time After: 0.01017 seconds
Time Before: 0.01041 seconds
Time After: 0.01058 seconds
Time Before: 0.01141 seconds
Time After: 0.01396 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01066 seconds
Time After: 0.01828 seconds
Time Taken: 0.00762 seconds
Time Before: 0.02246 seconds
Time After: 0.02283 seconds
Time Before: 0.02432 seconds
Time After: 0.02554 seconds
Time Before: 0.02186 seconds
Time After: 0.02573 seconds
Time Taken: 0.00387 seconds
Time Before: 0.04688 seconds
Time After: 0.04704 seconds
Time Before: 0.05865 seconds
Time After: 0.05994 seconds
End call of global.php: 0.061852931976318
Time Before: 0.06791 seconds
Time After: 0.06813 seconds
Time Before: 0.07073 seconds
Time After: 0.07232 seconds
Time Taken: 0.00160 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109725'
Time Before: 0.09152 seconds
Time After: 0.09187 seconds
Page generated in 0.090495824813843 seconds with 9 queries, spending 0.0084145069122314 doing MySQL queries and 0.082081317901611 doing PHP things.
