Time Before: 0.00898 seconds
Time After: 0.01181 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01191 seconds
Time After: 0.01235 seconds
Time Before: 0.01261 seconds
Time After: 0.01275 seconds
Time Before: 0.01361 seconds
Time After: 0.01644 seconds
Time Before: 0.01283 seconds
Time After: 0.02059 seconds
Time Taken: 0.00776 seconds
Time Before: 0.02651 seconds
Time After: 0.02705 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02948 seconds
Time After: 0.03072 seconds
Time Before: 0.02577 seconds
Time After: 0.03096 seconds
Time Taken: 0.00519 seconds
Time Before: 0.05297 seconds
Time After: 0.05313 seconds
Time Before: 0.06391 seconds
Time After: 0.06515 seconds
End call of global.php: 0.067172050476074
Time Before: 0.07567 seconds
Time After: 0.07586 seconds
Time Before: 0.07818 seconds
Time After: 0.07964 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=10973', badlocation = 1
Time Before: 0.09828 seconds
Time After: 0.09858 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.097088098526001 seconds with 9 queries, spending 0.0085325241088867 doing MySQL queries and 0.088555574417114 doing PHP things.
