Time Before: 0.00154 seconds
Time After: 0.00210 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00218 seconds
Time After: 0.00271 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00297 seconds
Time After: 0.00310 seconds
Time Before: 0.00394 seconds
Time After: 0.00669 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00318 seconds
Time After: 0.01008 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01215 seconds
Time After: 0.01259 seconds
Time Before: 0.01418 seconds
Time After: 0.01607 seconds
Time Taken: 0.00189 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01150 seconds
Time After: 0.01634 seconds
Time Taken: 0.00483 seconds
Memory After: 2,261.820 KB
Time Before: 0.02190 seconds
Time After: 0.02202 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02394 seconds
Time After: 0.02529 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.02692699432373
Time Before: 0.02841 seconds
Time After: 0.02856 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03064 seconds
Time After: 0.03207 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789147380, location = '/forums/private.php?do=newpm&explain=1&u=109744', badlocation = 1
Time Before: 0.04434 seconds
Time After: 0.04467 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.043432950973511 seconds with 9 queries, spending 0.0091350078582764 doing MySQL queries and 0.034297943115234 doing PHP things.
