Time Before: 0.00155 seconds
Time After: 0.00197 seconds
Time Before: 0.00207 seconds
Time After: 0.00247 seconds
Time Before: 0.00270 seconds
Time After: 0.00282 seconds
Time Before: 0.00355 seconds
Time After: 0.00590 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00287 seconds
Time After: 0.00943 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01125 seconds
Time After: 0.01167 seconds
Time Before: 0.01511 seconds
Time After: 0.01641 seconds
Time Before: 0.01058 seconds
Time After: 0.01660 seconds
Time Taken: 0.00601 seconds
Time Before: 0.02173 seconds
Time After: 0.02250 seconds
Time Taken: 0.00077 seconds
Time Before: 0.02453 seconds
Time After: 0.02576 seconds
Time Before: 0.02882 seconds
Time After: 0.02897 seconds
Time Before: 0.03110 seconds
Time After: 0.03342 seconds
Time Taken: 0.00232 seconds
UPDATE session SET lastactivity = 1785288241, location = '/forums/private.php?do=newpm&explain=1&u=109759' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04597 seconds
Time After: 0.04637 seconds
