Time Before: 0.01663 seconds
Time After: 0.02480 seconds
Time Taken: 0.00817 seconds
Time Before: 0.02494 seconds
Time After: 0.02552 seconds
Time Taken: 0.00058 seconds
Time Before: 0.02582 seconds
Time After: 0.02599 seconds
Time Before: 0.02683 seconds
Time After: 0.02909 seconds
Time Taken: 0.00226 seconds
Time Before: 0.02606 seconds
Time After: 0.03368 seconds
Time Taken: 0.00762 seconds
Time Before: 0.04397 seconds
Time After: 0.04434 seconds
Time Before: 0.04660 seconds
Time After: 0.04781 seconds
Time Before: 0.04327 seconds
Time After: 0.04805 seconds
Time Taken: 0.00478 seconds
Time Before: 0.08520 seconds
Time After: 0.08538 seconds
Time Before: 0.12648 seconds
Time After: 0.12774 seconds
Time Before: 0.13801 seconds
Time After: 0.13819 seconds
Time Before: 0.14059 seconds
Time After: 0.14217 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109811' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.16041 seconds
Time After: 0.16075 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
