Time Before: 0.02181 seconds
Time After: 0.02891 seconds
Time Taken: 0.00710 seconds
Time Before: 0.02902 seconds
Time After: 0.02959 seconds
Time Taken: 0.00058 seconds
Time Before: 0.02985 seconds
Time After: 0.02997 seconds
Time Before: 0.03089 seconds
Time After: 0.03284 seconds
Time Taken: 0.00196 seconds
Time Before: 0.03005 seconds
Time After: 0.03815 seconds
Time Taken: 0.00810 seconds
Time Before: 0.04787 seconds
Time After: 0.04835 seconds
Time Before: 0.05106 seconds
Time After: 0.05235 seconds
Time Before: 0.04653 seconds
Time After: 0.05259 seconds
Time Taken: 0.00606 seconds
Time Before: 0.09457 seconds
Time After: 0.09479 seconds
Time Before: 0.63548 seconds
Time After: 0.63675 seconds
Time Before: 0.65057 seconds
Time After: 0.65078 seconds
Time Before: 0.65346 seconds
Time After: 0.65530 seconds
Time Taken: 0.00184 seconds
UPDATE session SET lastactivity = 1776998653, location = '/forums/private.php?do=newpm&explain=1&u=109836' WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.67595 seconds
Time After: 0.67629 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
