Time Before: 0.02388 seconds
Time After: 0.02987 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02998 seconds
Time After: 0.03051 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03078 seconds
Time After: 0.03103 seconds
Time Before: 0.03176 seconds
Time After: 0.03373 seconds
Time Taken: 0.00197 seconds
Time Before: 0.03110 seconds
Time After: 0.03801 seconds
Time Taken: 0.00691 seconds
Time Before: 0.04718 seconds
Time After: 0.04764 seconds
Time Before: 0.05066 seconds
Time After: 0.05191 seconds
Time Before: 0.04645 seconds
Time After: 0.05214 seconds
Time Taken: 0.00569 seconds
Time Before: 0.09180 seconds
Time After: 0.09195 seconds
Time Before: 0.11220 seconds
Time After: 0.11376 seconds
Time Taken: 0.00156 seconds
Time Before: 0.12178 seconds
Time After: 0.12194 seconds
Time Before: 0.12422 seconds
Time After: 0.12568 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109901' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.14236 seconds
Time After: 0.14271 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
