Time Before: 0.00219 seconds
Time After: 0.00279 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00287 seconds
Time After: 0.00321 seconds
Time Before: 0.00341 seconds
Time After: 0.00354 seconds
Time Before: 0.00429 seconds
Time After: 0.00671 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00359 seconds
Time After: 0.01176 seconds
Time Taken: 0.00818 seconds
Time Before: 0.01371 seconds
Time After: 0.01414 seconds
Time Before: 0.01660 seconds
Time After: 0.01783 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01302 seconds
Time After: 0.01802 seconds
Time Taken: 0.00500 seconds
Memory After: 2,261.703 KB
Time Before: 0.02611 seconds
Time After: 0.02630 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02897 seconds
Time After: 0.03021 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.032904863357544
Time Before: 0.03417 seconds
Time After: 0.03438 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03649 seconds
Time After: 0.03795 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=109967'
Time Before: 0.05174 seconds
Time After: 0.05195 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.050750970840454 seconds with 9 queries, spending 0.0078408718109131 doing MySQL queries and 0.042910099029541 doing PHP things.
