Time Before: 0.00137 seconds
Time After: 0.00188 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00194 seconds
Time After: 0.00235 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00258 seconds
Time After: 0.00271 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00348 seconds
Time After: 0.00605 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00278 seconds
Time After: 0.01041 seconds
Time Taken: 0.00763 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01251 seconds
Time After: 0.01292 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01429 seconds
Time After: 0.01553 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01188 seconds
Time After: 0.01572 seconds
Time Taken: 0.00384 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.523 KB
Memory Used: 132.898 KB
Time Before: 0.02086 seconds
Time After: 0.02098 seconds
Memory Before: 3,437.625 KB
Memory After: 3,438.141 KB
Time Before: 0.02289 seconds
Time After: 0.02414 seconds
Memory Before: 3,525.422 KB
Memory After: 3,526.016 KB
End call of global.php: 0.025812149047852
Time Before: 0.02724 seconds
Time After: 0.02739 seconds
Memory Before: 4,163.281 KB
Memory After: 4,163.711 KB
Time Before: 0.03014 seconds
Time After: 0.03155 seconds
Memory Before: 4,444.844 KB
Memory After: 4,446.531 KB
SET lastactivity = 1785420197, location = '/forums/private.php?do=newpm&explain=1&u=109968'
Time Before: 0.04447 seconds
Time After: 0.04473 seconds
Memory Before: 4,918.695 KB
Memory After: 4,918.922 KB
Page generated in 0.043534994125366 seconds with 9 queries, spending 0.0079669952392578 doing MySQL queries and 0.035567998886108 doing PHP things.
