Time Before: 0.02263 seconds
Time After: 0.03303 seconds
Time Taken: 0.01039 seconds
Time Before: 0.03313 seconds
Time After: 0.03358 seconds
Time Before: 0.03394 seconds
Time After: 0.03420 seconds
Time Before: 0.03508 seconds
Time After: 0.03783 seconds
Time Taken: 0.00275 seconds
Time Before: 0.03428 seconds
Time After: 0.04169 seconds
Time Taken: 0.00741 seconds
Time Before: 0.05251 seconds
Time After: 0.05296 seconds
Time Before: 0.05567 seconds
Time After: 0.05688 seconds
Time Before: 0.05187 seconds
Time After: 0.05707 seconds
Time Taken: 0.00520 seconds
Time Before: 0.08684 seconds
Time After: 0.08705 seconds
Time Before: 0.11289 seconds
Time After: 0.11415 seconds
Time Before: 0.12656 seconds
Time After: 0.12694 seconds
Time Before: 0.12974 seconds
Time After: 0.13123 seconds
UPDATE session SET lastactivity = 1789147819, location = '/forums/private.php?do=newpm&explain=1&u=109970' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.15111 seconds
Time After: 0.15149 seconds
