Time Before: 0.03532 seconds
Time After: 0.04684 seconds
Time Taken: 0.01152 seconds
Time Before: 0.04694 seconds
Time After: 0.04741 seconds
Time Before: 0.04770 seconds
Time After: 0.04785 seconds
Time Before: 0.04863 seconds
Time After: 0.05129 seconds
Time Taken: 0.00266 seconds
Time Before: 0.04791 seconds
Time After: 0.05540 seconds
Time Taken: 0.00750 seconds
Time Before: 0.06513 seconds
Time After: 0.06551 seconds
Time Before: 0.06794 seconds
Time After: 0.06911 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06449 seconds
Time After: 0.06933 seconds
Time Taken: 0.00484 seconds
Memory After: 2,261.820 KB
Time Before: 0.12191 seconds
Time After: 0.12206 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.14317 seconds
Time After: 0.14440 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.15577 seconds
Time After: 0.15591 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.15871 seconds
Time After: 0.16014 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789025753, location = '/forums/private.php?do=newpm&explain=1&u=109971' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.18184 seconds
Time After: 0.18208 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
