Time Before: 0.00217 seconds
Time After: 0.00281 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00290 seconds
Time After: 0.00359 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00380 seconds
Time After: 0.00399 seconds
Time Before: 0.00461 seconds
Time After: 0.00765 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00403 seconds
Time After: 0.01250 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01525 seconds
Time After: 0.01570 seconds
Time Before: 0.01823 seconds
Time After: 0.01950 seconds
Time Before: 0.01459 seconds
Time After: 0.01968 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02474 seconds
Time After: 0.02490 seconds
Time Before: 0.02687 seconds
Time After: 0.02811 seconds
End call of global.php: 0.029749155044556
Time Before: 0.03110 seconds
Time After: 0.03131 seconds
Time Before: 0.03327 seconds
Time After: 0.03470 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109989', badlocation = 1
Time Before: 0.04700 seconds
Time After: 0.04726 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.046086072921753 seconds with 9 queries, spending 0.0089352130889893 doing MySQL queries and 0.037150859832764 doing PHP things.
