Time Before: 0.00186 seconds
Time After: 0.00233 seconds
Time Before: 0.00240 seconds
Time After: 0.00291 seconds
Time Before: 0.00318 seconds
Time After: 0.00332 seconds
Time Before: 0.00421 seconds
Time After: 0.00687 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00340 seconds
Time After: 0.01049 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01298 seconds
Time After: 0.01340 seconds
Time Before: 0.01618 seconds
Time After: 0.01752 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01229 seconds
Time After: 0.01770 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02264 seconds
Time After: 0.02276 seconds
Time Before: 0.02499 seconds
Time After: 0.02627 seconds
End call of global.php: 0.028658866882324
Time Before: 0.03003 seconds
Time After: 0.03026 seconds
Time Before: 0.03231 seconds
Time After: 0.03372 seconds
SET lastactivity = 1776609361, location = '/forums/private.php?do=newpm&explain=1&u=110024', badlocation = 1
Time Before: 0.04614 seconds
Time After: 0.04642 seconds
Page generated in 0.045209884643555 seconds with 9 queries, spending 0.0083701610565186 doing MySQL queries and 0.036839723587036 doing PHP things.
