Time Before: 0.00150 seconds
Time After: 0.00199 seconds
Time Before: 0.00205 seconds
Time After: 0.00262 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00287 seconds
Time After: 0.00298 seconds
Time Before: 0.00374 seconds
Time After: 0.00590 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00303 seconds
Time After: 0.00930 seconds
Time Taken: 0.00627 seconds
Time Before: 0.01219 seconds
Time After: 0.01261 seconds
Time Before: 0.01422 seconds
Time After: 0.01549 seconds
Time Before: 0.01136 seconds
Time After: 0.01567 seconds
Time Taken: 0.00431 seconds
Time Before: 0.02086 seconds
Time After: 0.02098 seconds
Time Before: 0.02294 seconds
Time After: 0.02416 seconds
Time Before: 0.02724 seconds
Time After: 0.02741 seconds
Time Before: 0.03053 seconds
Time After: 0.03218 seconds
Time Taken: 0.00166 seconds
UPDATE session SET lastactivity = 1777123643, location = '/forums/private.php?do=newpm&explain=1&u=110040', badlocation = 1 WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.04732 seconds
Time After: 0.04774 seconds
