Time Before: 0.01700 seconds
Time After: 0.02107 seconds
Time Taken: 0.00407 seconds
Time Before: 0.02115 seconds
Time After: 0.02162 seconds
Time Before: 0.02184 seconds
Time After: 0.02198 seconds
Time Before: 0.02276 seconds
Time After: 0.02526 seconds
Time Taken: 0.00250 seconds
Time Before: 0.02203 seconds
Time After: 0.02941 seconds
Time Taken: 0.00738 seconds
Time Before: 0.03572 seconds
Time After: 0.03598 seconds
Time Before: 0.03844 seconds
Time After: 0.03974 seconds
Time Before: 0.03500 seconds
Time After: 0.03995 seconds
Time Taken: 0.00495 seconds
Time Before: 0.06176 seconds
Time After: 0.06194 seconds
Time Before: 0.07506 seconds
Time After: 0.07631 seconds
Time Before: 0.08665 seconds
Time After: 0.08688 seconds
Time Before: 0.08978 seconds
Time After: 0.09129 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110053' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.10778 seconds
Time After: 0.10811 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
