Time Before: 0.00976 seconds
Time After: 0.01394 seconds
Time Taken: 0.00418 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01402 seconds
Time After: 0.01455 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01483 seconds
Time After: 0.01501 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01596 seconds
Time After: 0.01831 seconds
Time Taken: 0.00235 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01508 seconds
Time After: 0.02312 seconds
Time Taken: 0.00804 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.02910 seconds
Time After: 0.02956 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.03199 seconds
Time After: 0.03327 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.02842 seconds
Time After: 0.03345 seconds
Time Taken: 0.00503 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.06023 seconds
Time After: 0.06043 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.07312 seconds
Time After: 0.07439 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.076136112213135
Time Before: 0.08222 seconds
Time After: 0.08244 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.08515 seconds
Time After: 0.08673 seconds
Time Taken: 0.00158 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=110065'
Time Before: 0.10118 seconds
Time After: 0.10147 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.10029602050781 seconds with 9 queries, spending 0.008357048034668 doing MySQL queries and 0.091938972473145 doing PHP things.
