Time Before: 0.00259 seconds
Time After: 0.00334 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00346 seconds
Time After: 0.00390 seconds
Time Before: 0.00415 seconds
Time After: 0.00431 seconds
Time Before: 0.00527 seconds
Time After: 0.00736 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00438 seconds
Time After: 0.01301 seconds
Time Taken: 0.00863 seconds
Time Before: 0.01643 seconds
Time After: 0.01701 seconds
Time Taken: 0.00058 seconds
Time Before: 0.02056 seconds
Time After: 0.02174 seconds
Time Before: 0.01542 seconds
Time After: 0.02200 seconds
Time Taken: 0.00658 seconds
Time Before: 0.03112 seconds
Time After: 0.03140 seconds
Time Before: 0.03502 seconds
Time After: 0.03629 seconds
End call of global.php: 0.039259910583496
Time Before: 0.04121 seconds
Time After: 0.04137 seconds
Time Before: 0.04420 seconds
Time After: 0.04571 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=110081', badlocation = 1
Time Before: 0.05963 seconds
Time After: 0.05995 seconds
Page generated in 0.058517932891846 seconds with 9 queries, spending 0.0079784393310547 doing MySQL queries and 0.050539493560791 doing PHP things.
