Time Before: 0.00686 seconds
Time After: 0.01092 seconds
Time Taken: 0.00406 seconds
Time Before: 0.01104 seconds
Time After: 0.01151 seconds
Time Before: 0.01178 seconds
Time After: 0.01197 seconds
Time Before: 0.01267 seconds
Time After: 0.01492 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01203 seconds
Time After: 0.02042 seconds
Time Taken: 0.00839 seconds
Time Before: 0.02671 seconds
Time After: 0.02718 seconds
Time Before: 0.02961 seconds
Time After: 0.03080 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02596 seconds
Time After: 0.03103 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.703 KB
Time Before: 0.04580 seconds
Time After: 0.04598 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05855 seconds
Time After: 0.05982 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.07072 seconds
Time After: 0.07087 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07392 seconds
Time After: 0.07535 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110088' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.09226 seconds
Time After: 0.09250 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
