Time Before: 0.00191 seconds
Time After: 0.00237 seconds
Time Before: 0.00244 seconds
Time After: 0.00315 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00361 seconds
Time After: 0.00382 seconds
Time Before: 0.00465 seconds
Time After: 0.00684 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00387 seconds
Time After: 0.01030 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01271 seconds
Time After: 0.01315 seconds
Time Before: 0.01581 seconds
Time After: 0.01705 seconds
Time Before: 0.01163 seconds
Time After: 0.01723 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02428 seconds
Time After: 0.02447 seconds
Time Before: 0.02678 seconds
Time After: 0.02802 seconds
End call of global.php: 0.029789924621582
Time Before: 0.03112 seconds
Time After: 0.03127 seconds
Time Before: 0.03439 seconds
Time After: 0.03588 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=110094', badlocation = 1
Time Before: 0.05107 seconds
Time After: 0.05136 seconds
Page generated in 0.049678802490234 seconds with 9 queries, spending 0.0081520080566406 doing MySQL queries and 0.041526794433594 doing PHP things.
