Time Before: 0.01145 seconds
Time After: 0.01406 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01417 seconds
Time After: 0.01460 seconds
Time Before: 0.01485 seconds
Time After: 0.01499 seconds
Time Before: 0.01579 seconds
Time After: 0.01796 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01507 seconds
Time After: 0.02219 seconds
Time Taken: 0.00712 seconds
Time Before: 0.02680 seconds
Time After: 0.02702 seconds
Time Before: 0.02951 seconds
Time After: 0.03071 seconds
Time Before: 0.02602 seconds
Time After: 0.03090 seconds
Time Taken: 0.00488 seconds
Time Before: 0.05602 seconds
Time After: 0.05615 seconds
Time Before: 0.24525 seconds
Time After: 0.24649 seconds
Time Before: 0.25358 seconds
Time After: 0.25375 seconds
Time Before: 0.25645 seconds
Time After: 0.25800 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110116', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.27315 seconds
Time After: 0.27341 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
