Time Before: 0.01770 seconds
Time After: 0.02453 seconds
Time Taken: 0.00683 seconds
Time Before: 0.02464 seconds
Time After: 0.02506 seconds
Time Before: 0.02529 seconds
Time After: 0.02543 seconds
Time Before: 0.02633 seconds
Time After: 0.02876 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02550 seconds
Time After: 0.03301 seconds
Time Taken: 0.00751 seconds
Time Before: 0.04139 seconds
Time After: 0.04182 seconds
Time Before: 0.04345 seconds
Time After: 0.04466 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04067 seconds
Time After: 0.04489 seconds
Time Taken: 0.00421 seconds
Memory After: 2,261.703 KB
Time Before: 0.07905 seconds
Time After: 0.07923 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 1.42943 seconds
Time After: 1.43089 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 1.44228 seconds
Time After: 1.44245 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 1.44483 seconds
Time After: 1.44626 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110117' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 1.46648 seconds
Time After: 1.46676 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
