Time Before: 0.00698 seconds
Time After: 0.01084 seconds
Time Taken: 0.00385 seconds
Time Before: 0.01092 seconds
Time After: 0.01131 seconds
Time Before: 0.01154 seconds
Time After: 0.01166 seconds
Time Before: 0.01238 seconds
Time After: 0.01493 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01171 seconds
Time After: 0.01933 seconds
Time Taken: 0.00762 seconds
Time Before: 0.02506 seconds
Time After: 0.02541 seconds
Time Before: 0.02810 seconds
Time After: 0.02932 seconds
Time Before: 0.02430 seconds
Time After: 0.02955 seconds
Time Taken: 0.00525 seconds
Time Before: 0.04678 seconds
Time After: 0.04698 seconds
Time Before: 0.05716 seconds
Time After: 0.05837 seconds
Time Before: 0.06669 seconds
Time After: 0.06699 seconds
Time Before: 0.06975 seconds
Time After: 0.07136 seconds
Time Taken: 0.00161 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110151', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.08814 seconds
Time After: 0.08845 seconds
