Time Before: 0.00206 seconds
Time After: 0.00261 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00272 seconds
Time After: 0.00326 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00359 seconds
Time After: 0.00380 seconds
Time Before: 0.00462 seconds
Time After: 0.00723 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00387 seconds
Time After: 0.01066 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01244 seconds
Time After: 0.01280 seconds
Time Before: 0.01532 seconds
Time After: 0.01657 seconds
Time Before: 0.01188 seconds
Time After: 0.01674 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02172 seconds
Time After: 0.02189 seconds
Time Before: 0.02379 seconds
Time After: 0.02501 seconds
Time Before: 0.02918 seconds
Time After: 0.02935 seconds
Time Before: 0.03236 seconds
Time After: 0.03384 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110155', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04820 seconds
Time After: 0.04856 seconds
