Time Before: 0.00148 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00238 seconds
Time Before: 0.00265 seconds
Time After: 0.00280 seconds
Time Before: 0.00380 seconds
Time After: 0.00668 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00287 seconds
Time After: 0.01179 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01371 seconds
Time After: 0.01414 seconds
Time Before: 0.01663 seconds
Time After: 0.01784 seconds
Time Before: 0.01304 seconds
Time After: 0.01811 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02421 seconds
Time After: 0.02436 seconds
Time Before: 0.02695 seconds
Time After: 0.02818 seconds
Time Before: 0.03131 seconds
Time After: 0.03150 seconds
Time Before: 0.03465 seconds
Time After: 0.03631 seconds
Time Taken: 0.00167 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=110176' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04995 seconds
Time After: 0.05061 seconds
Time Taken: 0.00066 seconds
