Time Before: 0.00261 seconds
Time After: 0.00365 seconds
Time Taken: 0.00104 seconds
Time Before: 0.00376 seconds
Time After: 0.00424 seconds
Time Before: 0.00489 seconds
Time After: 0.00537 seconds
Time Before: 0.00636 seconds
Time After: 0.00849 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00545 seconds
Time After: 0.01430 seconds
Time Taken: 0.00885 seconds
Time Before: 0.01702 seconds
Time After: 0.01743 seconds
Time Before: 0.02200 seconds
Time After: 0.02321 seconds
Time Before: 0.01620 seconds
Time After: 0.02345 seconds
Time Taken: 0.00726 seconds
Time Before: 0.02988 seconds
Time After: 0.03017 seconds
Time Before: 0.03264 seconds
Time After: 0.03386 seconds
End call of global.php: 0.036702871322632
Time Before: 0.03795 seconds
Time After: 0.03808 seconds
Time Before: 0.04022 seconds
Time After: 0.04167 seconds
SET lastactivity = 1789103914, location = '/forums/private.php?do=newpm&explain=1&u=110197'
Time Before: 0.05476 seconds
Time After: 0.06915 seconds
Time Taken: 0.01439 seconds
Page generated in 0.0538010597229 seconds with 9 queries, spending 0.022195100784302 doing MySQL queries and 0.031605958938599 doing PHP things.
